so i diagnose my cel and i got a code 41 which is my o2 sensor and a 43 which is my fuel supply system and is it my fuel pump that needs to be replace or fuel pump, injectors, or what.....i need to know what part of my fuel system needs to be replace.....my car has 291058 original mile.....engine and everything is original.....any input would be great
cel code help
Code 43 usually ends up being thrown because of the o2 sensor as well. I have yet to see a code 43 case that was actually related to the fuel supply system itself.
Replace that o2 sensor with a brand new Denso or NTK unit ONLY. Do not use a Bosch sensor (and that's what most autoparts stores will sell you.) Get the right one for your car (EX/SE models have different sensor locations than LX/DX models.) Don't splice the wires. You run the risk of altering the resistance by doing so, which will result in improper readings being sent to the ECU.
by the way can the o2 sensor cause the car to lose power...what i mean is by having the car sitting in the drive way and just stepping on the gas until 2k rpm and then out of no where the car starts to lose power the rpm starts to drop and then i would have to give it more gas for the car to act normal again....this also happens when i drive under 2k rpm too....(car nevers dies though)...can the o2 sensor also do this
Yes, it can (though under 2k really isn't in the engine's powerband anyway.)
Other things can do that as well, such as failing ignition components... but the o2 sensor can do that as well. I've experienced it, as well as a code 43.
Tell me, does the CEL stay off until you hit highway speeds? That's when mine comes on, around 55mph.
Originally posted by deevergote View PostYes, it can (though under 2k really isn't in the engine's powerband anyway.)
well i really dont have to go fast for the engine to lose power i just have to be under 2k rpm and my check engine light doesnt even turn on while this power lost is happening, the light will just turn on later on during the drive
Well, like I said... under 2k isn't really in the engine's powerband. This isn't a V6 or V8... normal operating range should be between 2k and 3k.
Still, chaneg that o2 sensor. I'm quite certain that will fix your problems. Just be sure to get the right one. No Bosch, and no sensors made for a different model.
