battery fuse buzzing??
    okay so this is the second time it happens to me, i turned off my car and a buzzing noise was coming from the fuse box, was the battery fuse. i unplugged the battery and connected it again, it stopped, what might this mean??
    <-- LMFAO
    reply
    my big guess would be relays..next time when starts to buzz trying touching each one.it should give a little vibration,so you can detect it.
      i did that the 1st timee it ever did it, and it was the battery fuse. idk if i need to replace maybe the battery or the battery fuse in the fuse box..?
      <-- LMFAO
        reply
        why dont you give it a try..go to a junk yard look for a battery fuse with the same amp and swap it with your own,then borrow someone else battery and see if any difference.don't for get to check positive and negative cables that are screwed to your fuse box.also,check if the fuse box have ground too,under the box (if you remove the 4 or 3 bolts) you could see a black ground wire thats bolted to the body of the car.check that too.check if you have good engine to body ground.im not sure if your negative battery cable is bolted on the tranny,mine is.and finally that cable thats bolted on top of your valve and p/s bracket and right engine support bracket? check if the contact is clean and out of grease and grime..well thats all i can think of.gudluck
          Alright so i've checked it and it's not the battery fuse after all -_- it is the cooling fan relay fuse or soimething like that, i've taken it to two different mechanics but they both said different stuff. idk what to do or who to take it to..? you know how to fix that problem? cause i remember u said might be the relayy? well it is the cpooling fan relay..?
          <-- LMFAO
            reply
            what did both mechanics say? let me take a look at my cb7 project and look for that relay..but if you find it before me,try to disconnect it and look inside the contact point.try to clean the inside cuz im thinking its full of lithium grease or gum.(not chewing gum.lol) do that and let me know what happen.if problem still exist then you need to find a good one OR you could add a switch to control your fans.you'll need to find a good power source and a toggle switch and ground.just make sure to keep the wires tucked and away from moving parts and the header..ask your mechanics if they know how to do wiring so they can do it for u.
              they both said it had to be something either from the relays, and one just told me might be the whole wiring harness but that's bs, and also he said something bout when i turn the wipers on it goes to the fuse, so i was like what? and when i got home and it started buzzing again i hit the wipers and it stopped buzzing, now it hasn't buzzed at all, but i really wanna fix that, might be a problem right?
              <-- LMFAO
