Transmission Issues
    Transmission Issues
    I have a 91' Accord w/ 125k. The car recently has been having trouble shifting. When I take off out of my works parking lot it has trouble getting up to speed (tranny doesn't seem to do much) and then it will eventually rev and go into gear, but it doesn't feel like a shift (maybe a slip?). This only happens once in a while. More so however, the car has had issues shifting into 4th. It will rev and rev and then shift. It seems like it's getting very temperamental.
    My question is, would it be a possible TCU, or is this just a tranny going bad?
    I don't want to spend a lot of money on this car because it leaks fluids and needs timing belt, calipers, and front end work.
    Is it throwing a code for the TCU?
      No codes at all. Leads me to believe bad tranny?
        if you can , take the TCU out and inspect it .make sure it does not smell like burn't wires. also check the tranny fluid . mine started slipping and i bought a used tranny and it was the TCU going bad .
          Change the fluid with Honda ATF.
          Inspect the TCU, as suggested... and if you can get your hands on a known working one, try swapping it out.
          If neither of those things fix your problem, then yes, something in the transmission is most likely going bad. It can be repaired or replaced.
