Stiff e-brake
    Stiff e-brake
    I've noticed my 92 accord's e brake is pretty stiff when ripping it up. Every other hondas I drive seems to be easier to rip. Any suggestions???
    Do you have rear drums or discs?
      I have rear disc.
        Loosen the cables
          Will this work? similar?
          http://www.driveaccord.net/forums/showthread.php?t=8187
            This is what you need to adjust, take out the rear ash tray to get to it
              How many click am i suppose to be getting for the e brake? I have manual transmission.
                4 to 8 clicks.
                1996 Honda Civic LX 2009-2012
                2012 Kia Optima LX 2012-2013
                  mine clicks once or twice. and my rear wheels spin freely when its not engaged
                    Thanks for the replies. I'll see what I can do
                      I would also check how much the ebrake cam arms are moving on the rear calipers themselves, it's possible that something could be sticking. Also, you can disengage the cables from the calipers to check the cables for smoothness.
                        I love my e-brake being stiff... I mean at like 2-3 cliks (half way) the cable brake should lock the rear wheels from rolling already.
                        Checkout my MR: http://www.cb7tuner.com/vbb/showthread.php?t=165984
                          White lithium grease on the cables. Also spray some PB blaster on the lever attachments at the caliper.
