I got an extra head so I wanna do head work and I wanna know wut all I can get in combo with port and polish to get decent gain... While keeping stock bottom end
F22a1 Head Work
Good valves, upgraded valve springs, valve guides, retainers, a good camshaft, and an adjustable cam gear. All of these things can be found on bisimoto.com.
With a stock bottom end, though? I wouldn't. When the hed flows better, it makes power up high in the RPM range. Rev an old bottom end up high often, and you're asking for something to break. It's entirely possible that you'll put a piston into your expensive new head! Plus, the stock F22A compression is quite low. You'll see MUCH more from it if you increase compression. Get forged rods and pistons, and raise your comression level a bit. Replace all seals and gaskets, and get a tunable ECU (which you'll want even if you just do the head...)
Do it right, and you could easily make 220-250whp and still drive on pump gas.
id say if your doing any major work to an engine as such as upgrading the camshaft or vavles or anything in the head, get your ecu tuned to get full potential out of the upgrade. the stock ecu wouldnt recognize the upgraded camshaft because it thinks theres the stock one in it. therefore runing like shit
Damn straight deev, ppl need to use the stickies and/or all the other recources out there instead of asking ppl to think for them. Also, for a little bit of bump in compression, you can also shave(mill)(deck) the head while it's off. Mine is shaved .080, and with supporting mods(p&p, cam, adj. Gear, intake Mani, tb, header, etc...) it does make quite the difference. Zeal (I think) has a damn good compression calculator. Also, please, don't just go and get the head cut, do your research. Understand why you're nodding things, not just cause someone else has it done, or says it's beneficial. An engine is like an orchestra, all the parts have to work together. An orchestra wouldn't sound good if you replaced a sax with an electric guitar, even if Hendrix was playing it...H22a $1000
Msd 6al $ 200
Fuel cell $ 200
Carbs $ 125
Manifold $200
Lines etc $ 100
Header $ 400
GSR seats$ 100
Being the first and only streetable dd cb7 w 4 carbs...
PRICELESS!!!
Pics.. http://m891.photobucket.com/albums/alexiadanza/
Yes, it moves the cam and crank centerlines closer, wich is why it changes timing. That's why I bought the cam gear, mine is adjusted almost 2 degrees. Also, when I chose to shave so drastically, I accepted the fact that the $600 and 30+ hours I have into the head will be gone in the event of any damage, as it made the deck too thin to ever shave again. .080, or 2mm is the most I've ever heard of anyone shaving the head. That, and my one layer (ok, 2) head gasket give me .029 quench wich is perfect for tight bearings, forged rods and pump gas. Everything must be planned perfectly and researched thouroughly before any modding.H22a $1000
Msd 6al $ 200
Fuel cell $ 200
Carbs $ 125
Manifold $200
Lines etc $ 100
Header $ 400
GSR seats$ 100
PRICELESS!!!
Once you start with that stuff, everything is closely linked with everything else.
