5 lug conversion using full Prelude front end
    I looked on the thread that concerns the 5 lug conversion the all Prelude way on here and I have some questions. The user said something about a ball joint/taper reamer to make the hole for the ball joint larger to accommodate the Prelude joint. But I have a COMPLETE 99 Prelude sitting here that I am parting out. Its got the blades and all and the front end on my CB needs to be redone badly. I noticed that the thread said something about the sub frame would need to be installed on my CB to make it all work. I am pulling my engine to put the H22a4 in and I will have all the room in the world to work with to make all this easier. I hope somebody can answer my questions.
    look for the stickies about 5 lug and check my old posts and you will find a few older 5 lug threads there
      I read the COMPLETE 12 page 5 lug article and I got the info I needed but just not quite sure about the LCA crossmember. I am hoping that it might swap out and correct the positive camber problem everybody had using Prelude arms.
