Ok so here's what happens out of know where a few weeks ago a buddy told me that my reverse lights were on while i was driving...since he told me that i also noticed that evrytime i hit my brakes all the lghts inside my car get brighter and so do my front turn signals. I tried looking for a bad ground but no luck and I've also checked all my fuses and there all good. Dos anyone know what the problem might be. I have a 1990 accord by the way. Any help would be appreciated thanks
electrical problem...can anyone help?
You need a copy of the Helms for the wiring diagrams, and a multimeter. The Horn, Brake lights circuit is joined to the Small Lights circuit, find out where. You'll have to disconnect all the Small Lights and Horn/Brake circuit components and fuses as they all connected to ground at the chassis and to positive at the same battery. One you've done this, the joined section will present itself.
The Reverse switch may be damaged or the issue may be related to your other problem since all three circuits (reverse, small lights, and brake/horn) have components (light bulbs) in the tail lights.
Happy hunting.1997 Honda Accord EX-V6:
Originally posted by James MatteuYou have to consider the results of your test in an objective manner, or as the country folk like to say, "son, you gotta be smarter than what you're workin' with."
