I have an f22a w/k&n filter, short ram intake, h23 intake manifold, with 2 butterfly spacers,w/butterfly delete, adjustable fuel pressure regulator, msd blaster 2 coil, DC header, 2 1/4 exhaust, catylatic converter delete, and muffler. With A/C delete. My question is should I just use one of those spacers or use two, witch way would give me more air flow??? Please any advice would help me thanx in advance.
intake manifold spacer 2 or 1 w/butterfly delete?
The best for all around power is the 2 double stacked spacers with the IABs on the bottom and a gutted one on top. That'll retain the low-end torque and when they open up, gives you more plenum or runner volume for high end power.
But make sure when you delete the IABs in the gutted spacer that you also take out the rod and fill the holes with JB weld and sand them smooth for the best results.
Originally posted by marcusv8thunder View PostHas anyone done no spacers and no butterfly spacer, just straight upper plenum connected to runners? Can that be done would like to know
It won't be 5whp with an F22A and gutted stock IAB plates. 2-3 maybe.
And just for added info... that MSD coil does nothing. That DC header offers little gain over a cheap $50 "ebay" header... you just paid for the name, CARB number, and slightly better build quality, and removing the cat offers very little gain... all that does is give the government more reason to crack down on tuners, making it harder to pursue our hobby.
Get a catalytic converter, please.
91 EX, body/chassis ~235,000; rebuilt f22a6 crate engine ~65,000 (3/2011)
Neuspeed Super Cup Kit (7/2010)
TAS rear drum-to-disc conversion (6/2010)
Above photo taken - 4/2010
