i have a 91 accord with a f22a4 i just replaced the fuel pump and im getting fuel to the fuel rail< i pulled the line off placed it into a gas can and turned my key to the on position and it pumped fuel into the can> i also replaced the spark plugs and im getting good spark to the plugs, but the car will only start if it has been sitting awhile but it will only run for a second and than it wont start again until it sits again.
f22a wont start
does it crank? could be main relay..AT WEST COAST MEET
cb7rush: who has the tongs?JDMxDB8: i got a thong on...
to get to see more of my cb click the link below.
http://www.cb7tuner.com/vbb/showthread.php?t=130922
help
Originally posted by knutson420 View Postim getting fuel to the rail y would i have to check the relay? and yes it cranks over.
help!!!!!!
go to the pump and see if it is getting power.Originally posted by Makaveli2kBe a man. Grab on the crank pulley with one hand, hold some chloroform over the air filter and "Shush it to death".Originally posted by AccrdkidHey did you earn your Red Wings? Red Wings being you muffed dived that coochie and tasted copper and got the red mustache.
No matter how far you go, the same path lies in front of you. "ユメクイ"
sounds like you relay is bad ........did you fix this already?Originally posted by Makaveli2kBe a man. Grab on the crank pulley with one hand, hold some chloroform over the air filter and "Shush it to death".Originally posted by AccrdkidHey did you earn your Red Wings? Red Wings being you muffed dived that coochie and tasted copper and got the red mustache.
ok so you said that you are geting fuel and spark? but it will not start.
well you would not get fuel if the main relay was bad it could be the distributor it can't be the timing belt cuz it turn the dist. so any more detail bout this?
but you should get a new main relay or get a few from the local jyback at it again
too much fuel
my relay was good i went and bought a new one and it did the same thing i traced to the ecm i just replaced that now it wont start at all so i checked the spark again of course it was still good but this time i noticed my plugs were soaked in fuel. so i disconnected my fuel pump and sprayed starting fluid in my throttle body and it started i came to the conclusion that im getting too much fuel. my nieghbor said it could be the fpr or the injectors. im dont have a way to test the pressure but i thought the regulator controlled the fuel pressure or am i wrong?
