i just purchase my CB7 2weeks ago, i'm looking to upgrade my suspension so i can get better handling and ride feel out of it. i would love to spend 2-3 thousand on it but i don't have that much to spend. i'd like to keep cost under $1,000. i plan on installing them myself so i could put more money towards the kit. what would be the best bang for the buck?
coil over kits
With $1000, your options are pretty wide open.
I'd personally suggest F2 Type-IIs. They're fully adjustable, and many people have good thigns to say about them.
If you don't mind not having one piece, Koni Yellow shocks and Ground Control coilover sleeves is also a very good setup.
Make sure you get a camber kit and replace your bushings while you're in there. Seems they'll be within your budget as well.
Funtion and Form Autolife Type 1 or Type 2.
If you're telling someone to get a part that they've never heard of, PLEASE don't abbreviate the name... that doesn't help at all.
Tein Basic is also a very good choice if you don't need serious handling, and want to retain as much comfort as possible.
Do your research. Get quality, not just what's cheap (you can get quality in your price range.) Research spring rates and damping rates, and make sure you get what suits your needs. You don't need race-spec parts for a car that will never be raced. Too many people get a super-stiff suspension because it's "racey", and they just end up with a car that's no fun to drive.
Be sure to take other things into consideration as well... suspension bushings, ball joints, axles, tires, camber kit (don't cheap out here either... Ingalls or SPC are the only ones I'd suggest... cheapies are very dangerous!) You'll also need an alignment.
http://www.cb7tuner.com/vbb/showthread.php?t=179Originally posted by Need4speed View Postthanks guys, i'm researching as we speak. know what's the difficulty level on installing the full coil
over suspension? i would like to do it myself but at the same time i don't want to f anything up.
I keep forgetting what the difference is between the Type 1 and the Type 2... I recall the Type 2 being the one that stickydiljoe helped develop specifically for the CB platform. Does that just have greater adjustability?
I'm not a fan of full coilovers myself... I have no use for them, and I'd prefer to leave the adjustments to the designers. I love my H&R springs and Koni shocks!
Type I = Only height adjustable.Originally posted by deevergote View PostI keep forgetting what the difference is between the Type 1 and the Type 2... I recall the Type 2 being the one that stickydiljoe helped develop specifically for the CB platform. Does that just have greater adjustability?
Type II = Height and dampening ajustable.
They don't. You need a camber kit.Originally posted by Need4speed View Postokay so if the front coilovers have camber control on it, is there a need to a separate camber kit?
There's different "best setups" depending on what you're planing on doing with the car / suspension.Originally posted by Need4speed View Postso is it better to do a full coilover setup or the 2 piece springs and struts setup? i want the best setup and if i don't have to spend a lot and i can save money that's even better.
So, what are your wants and needs for the suspension?
What kind of driving do you do, with this question you will get mixed reviews, I had a spring and shock combo and I absolutely loved it, I had Tokiko Illumina adjustable struts and H&R race springs, I liked the comfort of the ride and pretty good handling aswell. In the end your decision should be made based on your type of driving and comfort you want.Originally posted by Need4speed View Postso is it better to do a full coilover setup or the 2 piece springs and struts setup? i want the best setup and if i don't have to spend a lot and i can save money that's even better.
