H23a1 swap help
    H23a1 swap help
    I am swaping a h23a1 in to my 91 cb .I have the motor out of both cars and I went step by step as I learnd here for the swap but. My car has internal coil but the h dosent what do I do? This is my daily driver so some help please. And yes I looked and either missed it or I'm dumb. And yes I used the f harness
    http://www.cb7tuner.com/vbb/showthre...highlight=coil
    COUPE K24
      Thanks for the quick answer but thoes links are for convertin dizzys I want to use the h23 dizzy and coil with the f22a4 harness it all plugs in but how do I get power to the coil
        That's what those links tell you. They show you how to convert an internal coil dizzy to external coil. Ignore the part that actually modifies the dizzy, since that's tenically done already with the external coil dizzy... and just follow the info regarding the wiring modifications.
          the EASIEST way to fix ur probem is to buy a h22 distributor..but it is the most expensive one unless u live off of craigslist....my .02
          my new turbo build
            That works u guys r the shit thanks for the patience I'll get some pics up when the swap Is done
              If I buy a jdm h22 dizzy do I have to do anything to the harness ?
                Nope. Plug n play.
                  Or you could follow the instructions in the links provided to convert to external... It's really not that hard. Your question has been answered.
                    ok I'm a little confused, why is it refered to as an h22 dizzy? is it something to do with the coils or what?
                    Being normal is probably the lamest thing you can try to be
                      Because it comes on an H22A engine.
                        its refered as a h22 dizzy because the h22 dizzy is a inner coil dizzy unlike the h23 dizzy which is outer coil.us tuners use these phrazes to seperate the two so theres no confusion.hope that helps...
                        my new turbo build
                          No, that is not why it is being referred to as the h22 dizzy... just the reason that it is being suggested.
                          And all this confusion could be avoided if the op just followed the instructions in the links above. I don't see why this is still an issue.
