wat f series vtec head can b put on my f22a1 and can give me a increase in power??
head swap
Originally posted by IntensePressure View Postwat f series vtec head can b put on my f22a1 and can give me a increase in power??
it would probably give you the better performance how much i couldnt tell you though lol.
i was actually thinking of doing the same for my f22a6 just haveing the same problem and dont know what head to swap on
good luck hope i helped alittle lol
i've got the f22a1 also, i thought about swapping for the f22b1 head done a little reading on it and decided against it because if i'm not mistaken the f22a1 head flow's better than the f22b1. not 100% sure. someone correct me if i'm wrong please i don't want to give wrongful information. as far as the g22 motor i know the from reading about it . if this is your first engine you may wanna have another set of experienced hands on it. just laying that out on the table. i'm not trying to be hateful or anything just trying to help outLast edited by 90AccordLowLife; 02-26-2011, 08:01 PM.
Neither. Both F-Series VTEC heads are not performance oriented. They have more power more so for the slightly higher compression than their VTEC mechanisms. The VTEC in both is more so for gas economy. The F22A does flow better so you are better off doing a simple port job than swapping cylinder heads.
An H-Series head is an entirely different story and is not a true bolt on application. It requires lots of research and know-how which you two do not yet possess. Only a handful of members have attempted, and even fewer have succeeded with a reliable setup.'94 JDM H22A: 178whp 146wtq
Originally posted by deevergoteIf you say double dutch rudder, i'm banning you...
Originally posted by Joey GT-R View PostNeither. Both F-Series VTEC heads are not performance oriented. They have more power more so for the slightly higher compression than their VTEC mechanisms. The VTEC in both is more so for gas economy. The F22A does flow better so you are better off doing a simple port job than swapping cylinder heads.
thnks i wasnt goin to do any of the wrk of my current engine i was gonna go get me another block to experiment on...
but thnks for the info imma stick to my head nd i am plannin on port nd polishin my head...
as for the g22 imma do major research on wat i need a so on nd also that will b a different engine
are you actually trying to form sentences?
Originally posted by Stephen Fry'It's now very common to hear people say, "I'm rather offended by that", as if that gives them certain rights. It's no more than a whine. It has no meaning, it has no purpose, it has no reason to be respected as a phrase. "I'm offended by that." Well, so fucking what?' —Stephen Fry
The F22B1 head is garbage compared to the F22A head.
The H22A head on the F22A block will give you a pathetic excuse for an H22A... low compression, low redline, and differing combustion chamber / cylinder bore diameters... which will be potential sources of detonation. Additionally, if you have no experience building engines, it is almost guaranteed to be thoroughly unreliable.
If you want VTEC, buy an H22A or F20B. If you want more details, just search. I personally answer this question in detail once or twice a week. It has been covered ad nauseum.
Just like with your turbo thread... PLEASE spend some time searching, and PLEASE start typing like you have a brain. If you can't do that, you won't find much help on this forum, and you will eventually get yourself banned. We really have no need for any more lazy people on this site. We have plenty already.
