Well, chances are a line just got reused.
Honestly, you can put a line with any number on it from the manifold to any part. The numbers are just kind of like a road map for techs. As long as you have a line going from the intake mani to the part that needs the vacuum you will be fine.
Focus on the lines that go to the black box on the firewall first. The top 3 need to go to a vacuum nipple, the short bottom needs to go to the "ufo" on the top on the charcoal canister, and the long bottom to the EGR. Then a line directly from the intake to the FPR. If you have cruise still, that needs connected. Then you will want a line from the mani to the IAB Actuator. I think that is all that are really required. If you have any left over vacuum nipples on the mani they will need capped. A small piece of line with a screw in it will work.
