Fan ON at all time.
    Fan ON at all time.
    Hello,
    My fan is running at all time in my CB. The car has been off for past 5 days and the when i turn it on, the fan is already running.
    What could the problem be?
    Thanks
    i would check the fuse.if you have something tied in to it then that will make it stay on.
      with the ignition on, locate your thermostat housing (the peice the lower radiator hose connects to at the engine) on that housing is a sensor, unplug the sensor, does the fan shut off?
        Could be a sensor or a relay.
        92 CB7 F22 5 speed.
        ^MY RIDE THREAD^
          it could also be the sensor .... the plug that goes in there if the 2 wires there are jumped it would make the fan run all the time
            If I remember right, the circuit providing electricity to our car's fans consists of a relay and sensor, and that temperature-activated sensor is NO. In other words, it has no electrical conductivity when the coolant is below some particular temperature. So check continuity between the pins of the sensor by your thermostat when the engine is cold, then when it's hot. If there's no change, then that's your problem.
            Otherwise it could be that your relay is stuck open.
              thanks guys, i will check that once i have time to look at it again. I will keep you updated
                Im having the same issue but it stays on at random times for a random amount of time. Sometimes it could be hours and other times its seconds.
                  I had that problem. i was actually low on coolant. lol
                    fixed. Please close.
