Radiator going bad?
    Radiator going bad?
    So i finnally got my toggle switches for my fan working and ran it for a while with fans on. i drove about 23 miles(friends house to home) and about 1/2 way on the freeway my car started to heat up agian. when i got home i felt my radiator hoses and the upper rad. hose was hot but the lower one was much much colder. could this mean its time for a new rad? i also replace my thermostat a month ago. Also one more thing, my car had an idle issue for a while and i had no air in system, no vacuum leaks, cleaned/bottomed fitv and iacv. i was messing around with it all of that stuff and i unpluged somthing i think its the MAF sensor on the TB? well it stoped my fluctuating idle but threw a CEL. is it safe to run it with out that sensor?
    When is the last time you flushed/changed your coolant?
    Check your hoses for any leaks, also inspect the radiator top and bottom, all around.
    If there is a radiator leak I believe it can be welded shut, but I don't think that's a good route to go down if you want longevity.
    MAF sensor question I have no idea.
    Current:
    2007 Acura TL Type-S 6MT KBP
    Past:
    1992 Honda Accord EX-R Sedan - RIP
    1991 Honda Accord EX-R Wagon - RIP 10/14/2010
    Words change lives. You just got to choose the right ones.
    Instagram: @CB7Nub
    Check out the more active "CB7Tuner Canada" Facebook group for CANADIAN members ONLY.
      i had a leak in my rad, i changed the rad and the thermostat was changed 2 months ago, i drove home and it still got hot, but not as hot as before and sure as hell not normal temp... what else could it be? btw i got radiator for 80 bucks brand new thru my school shop.
        hows your coolant look? hows your engine oil look? if you replaced the radiator and thermostat you might have a blown headgasket. how old is your water pump?
        COUPE K24
