I've searched the site and found several threads about stud removal nut but I have a problem. I was changing tires and one of the lugs on my rear tires just spins in place. How do I go about fixing this since I can't remove the lug to replace he stud or does the stud need to simply be pulled back into place?
Rear Stud Removal
he doesnt have to replace the hub..all he has to do is find a way to take the lug off and replace the stud..
Rush
Originally posted by DarkcloudBought 3 things, 1 that goes boom,1 that shades and 1 to go fasrer
Originally posted by bmxicansdso you got a boombox, sunglasses and rosettta stone?
So u think the surface inside the stud hole on the hub would be fine. My expereience has been that if the stud splines have wore out usually depending how long it has been that way then the surface is usually no good meanining that if he put a new one in it will in short time do the same thing If that is it even fits. All the ones i have seen the stud hole had been wollard out just enough that the stud dosn't get that tight fit. Just my experience though.Originally posted by cb7rush View Posthe doesnt have to replace the hub..all he has to do is find a way to take the lug off and replace the stud..
I agree, sounds like worn splines which would need hub replacement, other solutions offered above would be fine if the problem were just a broken stud.Originally posted by ugafan001 View PostSo u think the surface inside the stud hole on the hub would be fine. My expereience has been that if the stud splines have wore out usually depending how long it has been that way then the surface is usually no good meanining that if he put a new one in it will in short time do the same thing If that is it even fits. All the ones i have seen the stud hole had been wollard out just enough that the stud dosn't get that tight fit. Just my experience though.
