click when i turn left.
    A while back(5 months) my CV joint went out.. it was replaced and from there i never heard a clicking till now..its not really clicking.. its more like a loud pop..but recently its been getting worse and now its to the point where i can hear it pop as i brake hard and my steering wheel jerks a little to the left..my worry is that its a ball joint going out..but i wouldn't know much about this.. so help!! thanks guys!
    Ive got a 94 accord and mine kinda pops or i was thinking its the plastic rubbin on the 17's
      a test you can do is safely jack your car up and then hold the tire at the 12 and 6 o'clock positions and shake it, then do the same at the 3 and 9 o'clock position. That'll let you know if you have worn out upper, lower and tierod balljoints.
        It maybe your rack n pinion or a ball joint; my honda is sloppy on the driver side, tire shakes, pops on turns, and my steering is loose. I took a look at my rack and the boots gone. theirs some other things pointing to the rack as well; However, if all you need is a balljoint it's possible by hand if you have the tools, and it doesn't break the bank. I would take the tire off and take a look, and see if anything looks like it needs to be replaced. tie rods, u joint thing, bushings, bearings, etc. Get it done now while your down there.
          all my bushings are new so im guessing when i put everything back together i messed something up
            sock ride hight and stock ex rims
