Right side brake light failure ?
    Okay so my brake lamp is lit in my dashboard, indicating one or both of my brake lamps does not work when I hit on the brakes. Its the right side. Recently I replace the tail lights thought that it would fix the brake lamp. It didn't work. I then switched the the left side lamp assembly which was working to the right side connector, pressed on the brakes and still it didn't work.
    The problem is power is not being distributed to the one of the right side wires... Maybe a short somewhere? Do I need to purchase a new brake lamp switch?
    is your brake switch to far out
    If your brake lamp is lighting up on your dash board there might be something wrong with your brake switch or you have corrosion on your rear brake light socket. Grab a flashlight and look right on top your brake pedal there is a switch kind of looks like a sensor that's your brake switch if you press down on the brake pedal and its not hitting the switch that means its not good no more or you just might need to adjust it a size 14 wrench will do the job and just bring the switch more in where it will make contact.
      My brake lamp on the dash goes on and off at random. and all of my lights work, so i've never relied on it.
