my problem is i have a slight oil leak on my f22a1. it was leaking alot worse before but i replaced the oil pan gasket and valve cover gasket. i took my distributor off because it was leaking from where it sits in the head and it appears that the shop i took it to a while ago didn't even put an o-ring on it smh...
it's not leaking as bad as before but now there's a leak from somewhere above the oil filter because there's run off oil that's a little visible.
anyone know what it could be?
