F22 valve size misprint
    Just a heads-up, the f22b2 intake valve is actually 32mm in diameter. This is contrary to what is listed here:
    http://www.cb7tuner.com/vbb/showthread.php?t=41915
    and on several other similar threads around the internet. The f22b1 and f22ax intake valves are correctly listed at 34mm
    Sources:
    1) AEM Engine ID and Spec Chart
    2) 94 Accord Coupe Shop Manual Section 6 pages 39-40
    The more you know.
    this could explain some of the reason why the f22a's flow so much better.
