Major oil leak!!
    Major oil leak!!
    Ive been having a problem for like 2 days already, i have a major oil leak coming from the front on where the oil filter goes. Where the oil filter is screwed in there is a neck part that goes to the engine block, well the leak is coming from where that neck meets the block. Any idea what it could be? Thanks in advance guys...
    do you have an A6? chances are it's the o-ring that goes behind the oil cooler. it's like a 3 or 4 dollar part from Honda and it is a simple fix actually.
      It does sound like your oil cooler is leaking and if it is its just a oring.
      STANCE|WORKS
        Yes its an A6, actually its the similar specs from what ive heard, its actually a JDM F22a... is there a DIY on this? If not how can i replace it?
          it's really easy. drain your oil like you're going an oil change. remove the oil filter and then take i think a 30 or 33mm socket and use it to remove the thing that the oil filter screws to. you'll want to use a pipe on a large socket wrench for more leverage. the thing the filter screws to will come undone and the oil cooler will fall so you will want to have a free hand to catch it. from there just replace the o-ring on the pin the oil filter screws to. replace everything and bam you're done.
            thanks a-million bro! I will do this over the weekend and ill let you know how it went... Hhhmmm... Maybe ill do a DIY...
