Failure on timing belt procedure: damaged rear balancer driven pulley 12 bolt
    Hi guys! I tried to change the timing belt on a F20Z2 of a 94 cc7, the timing belt procedure is the same as ours. All was good, it just remained for me to exctract the 12 bolt of the rear timing balancer belt driven pulley, but it was too tightened. So what had to arrive, arrived! And i damaged the bolt!
    1/ Who has already had this case?
    2/ How can pull off this bolt?
    -Sorry if my english is bad, i try to improve it and do my best to be understood
    -Soon, you will come back to live...
    Bought from: Jack Lee ,Tommi ,408cb7 , xkjnboix
    I know there are special sockets that are used for stripped hex, but I don't think I've ever seen them for 12-point... You basically hammer on this socket, extract, and you pretty much need a new bolt to reinstall after you remove it.
    I <3 My Honda CB9!
    My Hondas
    1992 Integra LS Coupe (Sad story...)
    1995 Civic VP Coupe (Traded for->)
    2002 Civic EX Coupe (Traded for->)
    2006 Acura MDX (Long story...)
    1988 Accord DX Sedan (Donated to a friend)
    1992 Accord LX Wagon (Sad Story)
      I've done the same on a car or two at work, newer Civics, I believe. My solution of mega Vise Grips and a LOT of leverage, which is hard in cramped spaces like that, worked for me but I wouldn't advise it unless you really had to.
      1991 HONDA ACCORD EX COUPE
      2014 Volvo XC70 T6 AWD ----- 2000 Honda Odyssey LX
      2004 Nissan Altima 2.5 S ------ 1994 Toyota Corolla DX
      2001 Subaru Outback --------- 1990 Infiniti M30
        ~$20 at sears. I have one and it has saved my ass several times. Its a good thing to have for other bolts too.
          thanks guys
          EJX_Michael could you give me the name of the tool box? or a link please? i prefer this method rather than drill the bolt or shock it.
          Is Sears it the website "www.sears.com"?
            Been there/done that/different bolt though.
            http://www.sears.com/shc/s/search_10...oRedirect=true
              they carry a similar set at advance auto parts.
              you can get away with just marking the pulley with a dab of whiteout, instead of removing that bolt and using a screwdriver.
                Originally posted by baby_sham974 View Post
                thanks guys
                Oh shoot! I didn't even notice your location... You wouldn't have a sears for many many miles.
                You will have to go to a hardware store most likely. Print out the picture of that kit and ask someone at the store if they have anything like it.
                  So i looked for this boxtool here, i found it in Beta but the price is outrageously expensive! 400€ (~$(570) for a set 3pieces (17-19-21)
                  Good point! Sears does international shipping
                  @cp[mike]: thanks! Friends also advised me this method, simple and effective! i will test it
                    You dont need to remove that bolt to get everything lined up.
                    There are marks on the block you can use to line up the pulley.
                      It's true for the cam pulley, the front and center timing balancer driven pulley, but i never saw marks for the rear. I'm not mechanic so if it's written in the service manual, i prefer to follow the instructions
