Car Won't Run Help Asap Please
    ok guy's i'm at a loss right now with my car. just got the car back from the shop got my Engine Rebuilt. Ran Fine for 2 days , i went out to go to the store and my car won't run Main Relay, New Ignition Coil. i have fuel and Spark. It is very Frustrating it will attempt to start but will not run. i have searched and i'm running outta ideas, I really need any help thanks in advance Guy's
    did you check the timing ?
    MRT: http://www.cb7tuner.com/vbb/showthread.php?t=196248
      not yet. i didn't even think of that.
        Make sure all battery and ground connections are clean and tight. I've had problems with dirty battery cables. The car would crank, but wouldn't start.
        How are you testing for spark and fuel?
          Timing and then compression test, if the timing checks out.
          www.PreludePower.com
          BB SQUAD MEMBER #28 V.2
            ^^^ Your gif is win.
            Project wagon! Much excite! 2018!
            That Sedan. Purchased '07-->Swap'd-->Tuck'd-->Wreck'd-->May '16
              My Mechanic is checking all of this for me. i just had the engine and Transmission rebuilt and the guy that done it keeps saying it's the distributor. but i have changed the ignition coil, the Battery,All Connections are Good and Clean. the fuel Filter. and i found the Fuel Pressure through turning the key and opening the fuel line from the filter. All the Grounds are good all Connector's are good and Tight. the Main Relay Was Replaced, All Fuses and Etc are Good. But My Mechanic is Going Outta Town Today and won't Be back till Mon. so i really won't know Anything More till then. I just Started My New job yesterday so i Really Don't Have much time to spend on it right now. But i will do what i can This weekend to keep searching for a solution. Thanks guy's
                ok so i got some good news and some bad news , good news car started and ran for about 20 mins until i shut it off. bad news is it will not run again, it will start but not run. i replace the ECU and IACV and my dad done something and it started and ran fine but he say's it must be a bad ground some where i have checked the ground from the battery to the tranny, the ground from the motor mount to the power steering bracket, from there to the valve cover am i missing any more? i'm really frustrated with this . i just dumped alot of money into the rebuild and i called the builder back and he is still saying that it's something external. tht i will have to pay another tow bill. if anyone has any more ideas please let me know. i really don't want to pay another tow bill. thanks in advanced guy
                  have you checked the ground from the battery to the frame?
                    yeah from what i've seen everything seems to be in order. But it's probably something simple that i'm just overlooking somehow
                      Oki Guy's So i have an Updadte, i had a friend coe by Cause i was lost with this car. And i feel like an idiot but it was the starter hangin up and i am so aggrivated but now know what it was my car will be back on the road tomorrow. once again thanks guys for all of the help and advice
