messed up idle.
    messed up idle.
    hey fellas. encountered a problem. as I was driving I came to a hard stop and not knowing my SRI filter came off. and as the light turned green a civic came by and gave me a thumbs down on my cb7. so ofcourse I smashed thru the gears to catch up to him only to get caught on another red light. and that is when I noticed my idle was bouncing. pulled over. popped the hood. saw the filter came off. if anyone knows how to resolve this problem it would be much appreciated! thanks guys.
    Check out the thread stuck at the top of this section marked "read this first". In there is a link to a thread that will tell you how to fix the VERY common erratic idle issue.
      fixed the idle issue but for some reason now the whole car shakes? i know its the motor but dont know whats causing the problem..
        i just fix mine as well.
        about to get my hands dirty!
          just got done looking thru the forum to see if i could diagnose the problem i have. i checked if i was having a misfire or a vacuum leak somewhere, nothing. idle is fine, nothing is loose, no lose of power/ no lag. the block just shakes now in neutral but idle is fine. not bouncing. could it be the timing? any help or suggestions are much appreciated. thanks guys.
            Could be motor mounts
            Originally posted by scudweiser
            i farted while i was getting head once, i was drunk.
