Basic tune upp?
    Basic tune upp?
    i want to know what is a basic tune up consist of and also if i want a tune up but not the basic tune up so that my car is in tip top shape what else should be included. anyone get me? sorry lol
    I'm no expert but:
    Basic Tune-Up
    - Spark Plugs
    - Ignition Wires (Spark Plug Wires)
    - Distributor Cap & Rotor
    - Air Filter (Inspect First For Cleanliness)
    - Oil Change
    - PCV
    In depth Tune-Up (includes the above listed, plus)
    - O2 Sensor
    - Coolant Flush And Refill
    - Fuel Filter
    - Check/Clean EGR Valve/System
    - Replace any dry or crack hoses
    - Possible transmission fluid and filter change (depending on last time it was look at)
    - Inspect brake pads and rotors
    - Inspect shocks/struts
    - Inspect exhaust system for cracks/severe rust
    - Inspect tie rods and suspension components (replace any if necessary)
    Also, for future reference, this information is readily available in the stickies section. Take a look at them as they have tons of useful information pertaining to our cars.
    The Lord watches over me!
    - D. Chappelle
      Basic tuneup would consist of changing.
      Spark plug cables
      spark plugs
      distributor cap and rotor
      fuel filter
      oil filter and oil
      air filter
      And if u want to go a lil further get.
      An icm or whole distributor
      a fuel pump and change your tranny fluid.
        price ranges? for both pls
          Research. Google and online-parts stores are your friend.
          Prices will be different nationwide.
          - D. Chappelle
            don't forget to check valve lash
              Parts that I picked up to do my tune-up 'cause my baby is running like sh!t. I'm getting like 8-9 mpg, she's back firing, and tons of hesitation under 2500 rpms.
              * 4 quarts Mobil 10W-40 motor oil
              * 1 Mobil M1-104 oil filter
              * 4 NGK platinum spark plugs
              * Denso spark plug wire set
              * Fram fuel filter
              * Distributor cap and rotor
              * Denso O2 sensor (but I can't get the old one out)
              I may pick up a new air filter. I have to inspect my current one.
              - D. Chappelle
                Another member posted this, see if this helps.
                http://cb7tuner.com/vbb/showthread.php?t=186304
