My car started to make a loud noise i couldn't figure out where it came from, well i figured out it was coming from the idle control valve because when i unplugged it the noise stops. Also the car turns off when i push the clutch in or idle's really low. Can the ICV be cleaned or something. Thanks in advance.
ICV Question
ICV Question
Originally posted by keepinitcleanI give it 2 weeks before you sell it.Tags: None
The IACV (Idle air control valve) can be cleaned. Unbolt it from the intake manny, unplug the sensor, and disconnect the coolant lines. Hit the inside of the IACV with carb cleaner, usually has alot of built up carbon. (there is a DIY of it here http://www.cb7tuner.com/vbb/showthre...light=IACV+diy)
I would also look into checking some of the other idle issue fixes to help with the low idle etc.PSN
Vash744
MRT 1992 EX Coupe "The Jerk"
2009 Subaru Impreza 2.5i Premium Hatchback
2008 Honda Fit Sport (Totaled out - Death by fallen tree)
1993 CB7 Sedan LX (Totaled out)
1991 CB7 Sedan EX (Dead and Junked)
Thanks
I appreciate it im going to do this sometime this week hopefully i don't have to replace it they're pretty expensive..
I cleaned it and it fixed the ideling problem but not the whining = [
