Need help asap rack n pinion
    i cant manage to get one of these dam bolts in for the rack its the one connected to the ps steel lines it wont screw in any ideas?
    almost 2 hours playing with this screw. now this shit needs to be moved cuz my apt is *** and keepps threating to tow it
    nobody? its the steel lines it wont thread into the rack =/
      1) Make sure it's the correct bolt
      2) Make sure the threads aren't stripped
      3) Make sure you're turning it the correct way.
        i gave up it wont catch idk why. now its all bent from trying to line it up right
          Better have it towed to a shop before it gets towed somewhere else!
            lol ima just drive it w/o ps i guess to a buddies shop, should be fine right? maybe just do manual rack dyi. i cant believe that one steel line is taking longer to work then it did to do the removal of the rack
              Yeah, driving it without PS for a little while won't hurt anything. Eventually, the rack can dry out, so definitely modify it so it won't destroy itself (or fix the system.)
              I currently have my PS belt cut, but I didn't remove the lines so the system would still have fluid in it.
                make sure to put the cap back in the rack so crap doesn't get in there.... and put a cap on the line too.. and obviously take off the power steering belt!
                92ex CB7<-SOLD 93ex CB9shiftingshift73C10
                  didnt think about the caps i will do that for sure
