Checked CEL and this happened. Some help please
    The check engine light stays on! What does this mean? I cant seem to find any information on it.
    At first I thought maybe I didnt plug it in right. But it gave me my TCU code so I know it is working.
    So what does it mean when it stays on and doesn't flash at all!?
    You don't have to like what he did, but I would hope that you can appreciate the time, money and love that went in to the build. If you can't, you're not really an enthusiast, just another dumb kid with a car.-visualpoet
    Money and Knowledge are never in the same sentence, because people with Money think they know it all, but people with knowledge, know better.-ragingasian
    I found this on another website, it's old but Deev made a post on it.
    http://www.hondahookup.com/forums/sh...d.php?t=148406
    according to him, it's shot.
      I'll go check it again.. But my car starts. It wasn't starting thats why I was checking but it just fired right up
        There's a thread from last week on that site that has the same information... from me. (hondahookup.com is where I got my start. Once I found this site, I used to go there to flame the morons, so I wouldn't do it here... but I ended up helping all the CB guys, and they made me a mod... )
        Anyway, a solid CEL usually means a bad ECU. If it's sporadic, then you could have a slightly damaged wire, or a slightly damaged solder joint in the ECU itself.
        I've had a solid CEL once... but it only happened briefly (the no-start culprit at that time was my ignitor or coil... I replaced both... neither had anything to do with he CEL, however.) I've never had that issue again.
        Just in case it IS the CEL going out, be on the lookout for a cheap replacement ECU. They're easy enough to find, and you can probably snag one for $20 or so.
          My car wouldnt start up if my computer was short would it? Because my car starts but it runs like crap for a little than finally runs normal. And it drives normal too.
            Just throwing this out there since it wasn't mentioned...but if you don't have a stored "cel code" and you jump the 2 wire plug under the glove box, the light will stay on solid. Every time I jump that wire when adjusting the timing, that light comes on solid until I remove the jumper. This is in my 90 EXR (both when it was the stock f22a4/ecu and f22a6/ecu).
