Power Window
    Power Window
    My window gets stuck...could it be the regulator or track?
    1992 Honda Accord EX (Rosewood) - RIP
    It will be the track, my window you to do same when i roll it up or down it would get stuck just go to the junk yard and just grab the track.but when you take it apart check to make sure that the window motor is working good Hope that helps you
    92 cb7 http://www.cb7tuner.com/vbb/showthread.php?t=176886
    91 cb9 wagon
      Have you pulled the door panel off to examine the issue? It could be as simple as the glass not properly set in. No need to go out and buy parts when it could be as simple as an adjustment.
        I forgot about that sorry about that. like josh said it could be the window off track
        91 cb9 wagon
          Does it slow down right before it gets stuck like its out of power? If so then the tracks might need to be lubricated
