check engine light and 02 sensor ?
    my check engine light is on and it check the code and they say it is 02 sensor
    it only flashes code 1 that is it. so I went ahead and replaced it. didn't know how old or how many mile on it. car has 228k so. but light is still on.
    but this car has the F22a6 block with F22a1 manifolds and ecu.
    thanks
    92 2 door lx auto Sold
    92 4 door lx auto 300k club
    92 4 door lx auto with f22a6 white
    not in photo 93 2 door ex white auto
    http://www.cb7tuner.com/vbb/showthread.php?t=21259
    check through this thread . did you buy a new 02 sensor ?
      replaced it with a brand new o2 sensor.
        I checked out your link and I already pulled the code it is number 1 which is 02 sensor. but I replaced it. when the car sits for a while you start the car engine light stays off for little bit then comes on. so the o2 sensor heater circuit is working. the car isn't getting bad gas mileage either so o2 sensor is sending signal to ecu.
          Did you use a Bosch o2 sensor? Because they don't work properly for our cars (why Bosch makes and sells them, I don't know... they NEVER work properly.)
            i never got a cel 1 for a o2 sensor, maybe check the connection or check continuity of the wiring going to the ecu. possible ecu fault.
              I had the same exact issue with another car (non honda) Turned out there was a short in the ecu. Got a friend who can let you borrow and ecu and try that?
              "Auto racing, bull fighting and mountain climbing are the only real sports....all others are games."
              - Ernest Hemingway
                True. I meant to comment on that... o2 sensor codes are usually 41 and 43. 41 is DEFINITELY the o2, and 43 (fuel supply system) is more often than not.
                edit: holy crap Val still exists!
                  x2
                  Oh and congrats on winning that bid on that house Val.
                  :edit:
                  OP did you try resting the ECU. The code will stay on continuously unless you reset it (disconnecting the battery and taking out the fuse for the ECU in the engine bay fuse box).
                  Henry R
                  Koni/Neuspeed
                  1992 Accord LX R.I.P
                  1993 Accord EX OG since 'o3
                  Legend FSM
                    Yeah I'm alive!
                    Thanks Henry... When are you going to come buy a house in Mass and let me help you out???
                    - Ernest Hemingway
                      yes it was a bosch o2 sensor. but I will reset the computer and check the code again.
                      if code comes back I will switch computer with my other 92 accord and see if light comes on the other car if it is the computer.
                      other accord is the same thing only 2 months apart on build date same trim.
                        Originally posted by Rusty View Post
                        Yeah I'm alive!
                        Hogwash! i will never move back to Mass (maybe back to the Taunton area but that remains uncertain) hey I think you and Eric need to throw another meet this time however it should be at the new crib! hint hint
                        I had no idea you and Eric got married though congrats.
                        Henry R
                        Koni/Neuspeed
                        Legend FSM
                          **Sorry to Thread Jack
                          You and a few select friends are more than welcome to come down and 'meet' any time but I will never host a public meet at my house again. I've had my fill of dangerous weapons, drugs, puke, and wayne!!!
                          - Ernest Hemingway
                            and random chicks barfing in Eric's teg. I will never forget that night...I think me and Eric were the only sober ones.. that was fun though and sure anytime you guys host a get together let me know.
                            Henry R
                            Koni/Neuspeed
                            Legend FSM
