200k on motor ... need some suggestions
    I hit 200k 2day and im just looking for some suggestions on how to maintain a bit better. Trying to look past the basic oil change every 3k-5k miles. So anything you guys lemme know thanks
    When is the last time you changed timing belt/water pump?
    My CB9/Wagon Thread Start to Finish:
    http://www.cb7tuner.com/vbb/showthre...ighlight=wagon
      Replace your timing belt and water pump if its due.Maybe flush your tranny and rad. There is not a 200k service last time I checked. My Se has 180,900 (but I am not shure how meany on the rebuild but its less then that)and all I want to do to it is the tranny flush.You can really take the mileage up super high on our cars and they dont require alot of crap done to keep them running, My green EX has 269.700 on it and I hot rod the crap out of it and it still has lots of life in it.
      Green EX http://www.cb7tuner.com/vbb/showthread.php?t=176536
      93 SE http://www.cb7tuner.com/vbb/showthread.php?t=210486
        08-09 i believe ... not 2 sure
          @thepowderblue how often you have to replace your water pump ?
            You wanna change your timimg belt and water pump at around every 60k.
            Be sure to stay on top of your water hoses as well, heater hose, etc ..
            The inexpensive parts seem to be the ones that fail most .. and cause the most $$ damage.
              replace timing belt every 60k mile keep oil changed and she will last 300k
              92 2 door lx auto Sold
              92 4 door lx auto 300k club
              92 4 door lx auto with f22a6 white
              not in photo 93 2 door ex white auto
                And beyond.
                I <3 My Honda CB9!
                My Hondas
                1992 Integra LS Coupe (Sad story...)
                1995 Civic VP Coupe (Traded for->)
                2002 Civic EX Coupe (Traded for->)
                2006 Acura MDX (Long story...)
                1988 Accord DX Sedan (Donated to a friend)
                1992 Accord LX Wagon (Sad Story)
                  PakaloloHonda and snakeman34 are wrong. you replace the timing belt and water pump every 90k on our cars.(I know that and its in the book) you only replace it every 90k under normal daily driving.
                    I like how in the owners manual the timing belt service at 90k is recommended only, not required lol. I guess thats true you don't need a timing belt untill it breaks
                      but if it brakes you MIGHT also need a valve job.
                      Ill say replace them at 90k if its just your daley driver but if you run your car very hard do it at 60k
                        make sure on that timing belt and water pump my car has 315K and the water pump seized i thought my car was dead other then that i just have the oil changed and i recently had to get a new radiator but that is all i do and my engine is still running strong
                          My motor has 262,3xx on it. Motor and trans runs awesome. Little oil leak but I bought every seal and gasket. Just to make sure they will not fail. Bought new timing belt and waterpump too. Show me an american car that runs with these kinda miles.
                            the timing belt is 60K for severe service (DDing in stop/go traffic, extreme climates, etc.) 90k for lighter duty (garaged grandma car, putt putting to the store every couple of days.) Or every 6 years, due to the rubber degrading and it being a critical part.
                            I had a grandma Accord a couple of years ago, 80k mi 91 sedan. Timing belt had never been changed. rot was crazy bad tho, it was from Long Island.
                            SO nothing special, just keep up with the maintenance.
                            1992 Accord Wagon (RETIRED)
                              thanks yall appreciate the help
