My F22A4 has over 309,000 miles. I got the car with 281,000. It was running very well, except it had no oil in the engine. It had been parked for a while, so I figured they just changed the oil and forgot to put new oil in. Turns out it was burning it. A quart every 700. And more recently a quart every 300.
I did a compression test and it was about 115 in the first three cylinders and 60 in the cylinder that is furthest over to the driver side.
I was not phased, as the car was running incredibly smooth.
But it is running rough all of a sudden. It seemed like a miss. I pulled the plug in the cylinder with low compression sure enough it was caked in oil.
I replaced the plugs thinking the car would run smoothly, as my 84 Accord used to do that, no such luck...it is still running rough.
Also the cylinder on the passenger side quickly gives a charred exhaust appearance to the plug. The middle two cylinders are clean.
What could I do next to try and squeeze more life out of this engine?
