I just bought my cb7 3 days ago and noticed it shifts pretty hard, which I've been reading is a trait of this car. I would like to hear your opinions. The previous owner changed the ATF but I don't know if it was Honda brand fluid or not. How much does that matter?
Do autos need Honda ATF only.
Honda ATF is reccomended by honda, you might get away with other fluids but its always safest to just buy honda ATF.
I've only changed 1 honda automatic transmission's fluid before and i made sure to use ATF.
There is a DIY in the DIY section on flushing your transmission, its done on a 6th gen accord so its very very easy to use for a cb7,
Yes, you should only use Honda ATF, but I've heard other people that have had great luck with synthetics.
Yes my name is Dang, Don't use in vain
1992 Honda Accord EX (Coupe/Bordeaux/Auto)
1992 Honda Accord EX (Coupe/Bordeaux/H22A MT)
2008 Honda Accord EXL (Coupe/SanMarino/6spd)
yeah the auto's do shift a little rough.
use synthetic atf and you will be fine. If you insist on using inferior non-synthetic atf then yes only honda (that's because honda's atf is better than non-synthetic )
...but No...you do NOT have to use honda atf...if you use synthetic (lasts longer protects better)
Even in the manual trannies there is aftermarket stuff that works just fine...old wives tale perpetuated by honda. Same with p/s fluid. My honda's steering wheels turn just as smoothly and quietly with aftermarket stuff...____
Originally posted by Tippey764 View PostYeah they used to sell ATF Z1 but it was discontinued in 2011
Now they sell DW-1
Originally posted by Tippey764 View PostIm not really sure because i don't own an automatic.
Originally posted by bcjammerx View PostEven in the manual trannies there is aftermarket stuff that works just fine...old wives tale perpetuated by honda. Same with p/s fluid. My honda's steering wheels turn just as smoothly and quietly with aftermarket stuff...
Of course the recommaneded fluid are the OEM Honda fluids for the A/T and PS. Using fluids that are not recommended by Honda is at your own risk.
