Airbag replacement????
    I have a 96 Accord that has a popped passenger side airbag and the bag is stuffed back in the dash and the horn/cruise dont work on the steering wheel so I assume the drivers airbag doesn't work either. I am going to buy a set of airbags on ebay but my question is are they just plug and play? Or will i have to do something to the computer as well.
    Some on ebay come with AB and modual will that do?
    Is there any pressurized gas cylinder i have to replace that fills the air bag with air?
    If i have to reset the computer how do I do it?
    Lastly what would be a reason for cruise and horn not to work? I checked the plugs and they are all connected.
    Sounds like your clock spring is broken in the driver steering column.
    And no its a pretty easy job, unbolt screw the old airbag and put the new one in its place, plug it up and reset the system ( newer hondas require a special sequence to reset an SRS light. Anyways this question would be better on cd5tuner.com
      Ahh thanks. When I had my boosted h22 in a cb7 is when i made this account. that has been since sold and just driving a daily now. thanks for the info though.
        Airbag is all self contained.
        The clockspring often gets burned up when the driver airbag pops due to the heat created when it goes off.
        1992 Accord Wagon (RETIRED)
