Originally posted by Tdub90
View Post
idle very low
Yeah mind does the same exact thing. Since that happened I've had to advance my spark timing because wouldnt want to start so I'm guessing something happened to my cam timing, or my valves. I'm gonna swap my FITV soon, but I doubt its going to help. I'm also going to compression test it soon. My bet is on bent valves.
WERD!Originally posted by KeeleDesign View PostMost vac leaks will cause higher idle problems, because it is receiving more air than whats being measured. That will also cause surging. (obviously this isn't your issue) And if your dead set on it for some odd reason, get some carb cleaner while the car is running and spray it around where you may think it's leaking, it's rev really high if so.
My first thought is that your idle screw is improperly set not allowing enough air to be combusted.
The IACV could have some to do with this, but every honda i had i deleted this and never had any type of idle issue. (that is not to say your engine could do the same)
Little things i would check first.
plugs, are they clean?
throttle cable is it properly adjusted?
idle screw is it allowing the correct amount of air to enter? this is important for driving and letting off the throttle as well as you don't want your car to fall on it's face everytime you let off the gas.
verify correct fuel pressure.
clean iacv and reinstall.
remove egr valve and see if it's stopped up.
Originally posted by deevergote View PostThere is also a thread (found in the "read here first" sticky at the top of this section) by HondaFan81 that tells you how to set your base idle.
ok, well I checked out that thread and have a couple of questions. I'm still learning so these might be simple questions but bear with me.
So where can I find the IACV in order to unplug it?
A the fuse I'm supposed to unplug for 10 seconds is marked?
Your iacv is directly on the front of your IM, just unplug it while the car is running. If it surges it's working.
To reset your computer. You can remove the fuse, or just un-hook your battery for an hour.
Have you checked base fuel pressure?
Is your air filter clean?
Do you have any CEL lights on?
Have you advanced your distributer just a hair? If you believe it's your timing, get a light and check to see what it's set at.
whats your setup?
Do the things in the order I have given last post and this one, and report back with accurate results."Self Renewed"
Originally posted by KeeleDesign View PostYour iacv is directly on the front of your IM, just unplug it while the car is running. If it surges it's working.
whats your setup?
setup as in what i got in my cb?
i have f22a, just a simple intake. got some subs in the trunk so i think thats why the idle is kinda low and not steady. it actually sits right at 800 which is what a few people said it should be at, but i thought it might be better to set it a lil higher because of the subs. I do have a capacitor so i dont drain the battery too much, but still notice a slight drop in rpm's when im sitting at a light and the bass hits
i will check the other things tho just to make sure things are running good
wait............ I never read where you said it surges.
Until now.
If it's suging, your IACV is bad , or you have a IM gasket leak, like I previously mentioned.
Surging is where the idle will go from 500 rpms up to 2000 rpms over and over without you touching the gas.
Most the time it won't trigger the cel."Self Renewed"
