My h22a head warped/cracked and i need a new one. this is the first time im ever going to pull a head off so is there anything to look for. also where do you suggest i get buy a head from? i was thinking junkyard but it still might be cracked/warped. i dont know of anywhere that is trusted and doesnt want a rediculous price.
H22a Head
Well, did it warp or crack or both? If its just warped, a machine shop should be able to shave it to be flat for anywhere from $40-100.
If cracked, id look for a new one. Preferably an h22a4 head, id prefer that since it has the spring type lma's instead of the hydraulics which are prone to failing. Drop your cams in and you're good to go.
As far as head casting goes, id venture to say they are identical, but I don't have any first hand knowledge on that.1991 Accord Ex - H22A - Omnipower Coilovers - Greddy SP2
1993 Civic Dx - D15B7 - T3/T04E - Ported head - Hole in block - May be going F swap
My Workout Log
Originally posted by LeungWell, I poked the big one in the head with the shovel while shouting at it "hey, you can't sleep here".
is the a4 better then the 93 jdm h22a head? i had a friend wanting to sell one from a blown h22, but he doesnt know much about it and he wanted 100 bucks. but i think from a blown motor the head would be damaged...Originally posted by 91H22ACB7 View PostWell, did it warp or crack or both? If its just warped, a machine shop should be able to shave it to be flat for anywhere from $40-100.
I would check Craigslist. I have seen them for $250 bucks, 200 on a good day.Originally posted by Drifting in 808 View Postthis is the first time im ever going to pull a head off so is there anything to look for.
I had to change a head on my old cd5 because it was overheated (not by me). It was not very hard. You have to follow the torque specs and tighten the head down in a specific order in stages. you will be fine.I put a f22a head on
The head could be warped, or a piston may have made contact... but you'd have to inspect it to find out.
The F22A head (they are all the same) has the ability to outflow the H22A head. However, the best head is the one that matches the block you have. If you have an H22A block, you want an H22A head.
Just by the fact that the h22a4 heads have spring type lmas, make sure you use the cams from the jdm motor. How was the motor 'blown'?Originally posted by Drifting in 808 View Postis the a4 better then the 93 jdm h22a head? i had a friend wanting to sell one from a blown h22, but he doesnt know much about it and he wanted 100 bucks. but i think from a blown motor the head would be damaged...1991 Accord Ex - H22A - Omnipower Coilovers - Greddy SP2
My Workout Log
Take a look at it, if its been smacked by a piston, you'll know. If it looks ok, get it shaved, replace the valve guide seals and maybe grind the valves while your in there.1991 Accord Ex - H22A - Omnipower Coilovers - Greddy SP2
My Workout Log
old post, i finnaly got the time to pull the head, i got it off right now and going to napa tomorrow to buy parts. i was gonna buy a head gasket set, water pump/timing belt. is there anything else im missing? the cam seals didnt look too bad and the head bolts looked like they were in good shape.
