megan header,new gasket?
    so i'm about to install a megan header soon. and i'm sure everyone knows the header will leak because of the gaskets. my question is where exactly does it leak? should i just replace ALL the gaskets with quality oem ones?
    Members' Ride Thread :http://www.cb7tuner.com/vbb/showthre...82#post2939682
    My CB7 Tribute Vid..https://www.youtube.com/watch?v=XqWFstSzLH8
    Track ready EK..https://www.youtube.com/watch?v=IoYKsoL0i7M
    exhaust gaskets are reusable but I would just put new ones in.
    1992 Accord EX Coupe >http://www.cb7tuner.com/vbb/showthre...00#post3060200
    Originally posted by keepinitclean
    I give it 2 weeks before you sell it.
      He's not asking about reusing gaskets. He's talking about the reputation that the gaskets you get with a Megan Racing header have for leaking.
      The Megan gaskets are hit or miss. Sometimes people have no problems, other times, they're terrible. I THINK they've started sending better gaskets, but I'm not sure.
      Get new quality gaskets if you're unsure, or take the chance with the ones they send you. If they leak, then it's just a little extra work to replace them. The Megan header won't be very difficult to get off if you're doing it a short time after installing it.
        This should help:
        http://www.cb7tuner.com/vbb/showthread.php?t=177723
        The manifold to head gasket can be reused but should be replaced. And the one from the header to cat as well. The biggest gasket issue is where the pieces of the header mate and the above link has a solution for that.
          Woops but still like i said he should just get new ones to be sure.
            Yeah, your advice wasn't bad, just not applicable to the topic. It's very true that gaskets shouldn't be reused when a good seal is required.
