F22B Dohc non vtec High Rpm
    Hey every body, i'm new on the forum and i got a little problem with my car ..
    When the Car is ​​hot, my idle when I hold the clutch and the car rolls, the rpm goes up like to 3000, but I don't give gas ... when my speed is less than about 10kmh, the idle down to 1000/1500 rpm!
    I Don't understant that lol,
    I'm a little bit Lost with this problem
    Thanks
    Mathyeu
    EGR system?
    Is the engine light on? if not then Idle Air Control Valve maybe
    UKDM 93 CB3 Page (1) H22A U2Q7 LSD
    UKDM 91 4ws Page (3) OEM Minter
    NOW H22A U2Q7 SWAPPED
      No The Engine light is not on..
      I clean up 2 weeks past
      iacv, throttle body, thermostat, injectors ..
      If it's the Erg, it is possible to clean it up ?
        Check for vacuum leaks.
          Check your tps.
          http://www.cb7tuner.com/vbb/showthread.php?t=173012
          wat?
            Thanks for your answers, it sounds that it's the same problem..
            i'm probalby supposed to swap an h23 intake ..
            it is dangerous to runs with this crazy idle ?!
            until i swap or change the TB
