i feel like im slipping in first gear in my 1991 honda accord.. also in second i have it vibrate but then in third im great... so if any one could tell me what you think i should do that would be great .....
tranny or clutch whats the problem??
If clutch is slipping you can smell it.. like burnt/rotten egg.Checkout my MR: http://www.cb7tuner.com/vbb/showthread.php?t=165984
Im been having the same problem with my transmission vibrations in 1st and 2nd and slight slippage in 1st..... the problem when taken down was found out to be the ring that disengages the clutch needs to be replaced and was eating up the clutch that was causing all the slippage and vibrations
replacement clutch is 60 bucks... if anything exedy makes a full face hd clutch that holds great... I think its stage 29. fuk stages. Find out what kinda hp you wanna make with your car then search for a clutch that will handle that... Do you sit in traffic alot? Then get a sprung disk for sure....K20z3
