h23 plenum a6 runner please help
    so i boosted the wagon this past week... ive had a h23 manifold sittin in my garage for a while now... i guess ima throw the plenum on the a6 runners... my question is do i run the iabs without the butterflies as a spacer? if i remember correctly some people do on na applications for more torque... i didnt know if this is the case with forced induction... if so, are the a6 and h23 iabs the same size?... would it be even better to double stack em? i cut out the inner port webbing on the plenum and will be doing the same on the iabs... basically turning the iabs and plenum into one big plenum w a6 runners... in my head it sounds good but i dont know if its beneficial or not... someone throw me a bone please...
    The IAB plates are the same. Yes, you can double stack them.
    I would imagine hollowing all that out is going to give you one hell of a weak bottom end. The whole point of the IAB system is to keep up flow velocity. Doing that defeats the whole purpose.
      so is it beneficial to double stack them? or would i be wasting time? also should i remove the butterflies out of the iabs? or is that what you meant by it gaining a weak bottom end?
        if your boosted i'd take the plates out all together
          Honestly, I would run an H23/A6 manifold unmodified (other than the combination of parts) with a double-stacked plate, IAB butterflies intact on one of them.
