I just replaced both of my outer tie rod ends using the walkthroughs on the forum and the torque specs from the Helms manual. Having done that though, I have a question regarding the torque specs. The Helms states that any bolts going through bushings need to be torqued once the vehicle is on the ground. Is that the case for the tie rod ends as well? If so, how the heck do you get a torque wrench on that castle nut with the wheels on and the car on the ground?
Tie rod end question
Torque in the air.Originally posted by doublfelix View PostI just replaced both of my outer tie rod ends using the walkthroughs on the forum and the torque specs from the Helms manual. Having done that though, I have a question regarding the torque specs. The Helms states that any bolts going through bushings need to be torqued once the vehicle is on the ground. Is that the case for the tie rod ends as well? If so, how the heck do you get a torque wrench on that castle nut with the wheels on and the car on the ground?
