ok so i have a 92 lx 5 speed bone stock.. i was beating on it while the gas light was on and when i pulled into the gas station it turned off and would'nt start again. WTF is wrong with my car?? lol It is trying to start but it almost sounds like its not getting gas.. Did i maybe clog something from running it so hard with no gas and all the shit at the bottom of the tank and clogged my fuel filter?? Please help me out i checked all the fuses and everything was fine i get power everywhere just wont start up..
car wont start
Your fuel pump most likely went out. Have someone turn the ignition on while you hold your ear over the fuel pump area (in trunk under seat). You should hear the pump turn on and build pressure. Once the pressure has reached a certain level, the noise will go away. If you don't hear a noise at all, chances are the pump is shot.
Do you hear the fuel pump turn on when you put the key into accessory mode? Can you check for fuel pressure? A clogged filter probably wouldn't lead to sudden failure like you've described.
Otherwise you may not have spark. Your distributor possibly failed -- it happened to me and that would cause your car to crank but not start. Any auto supply store should stock a spark indicator tool to tell you.
Main relay I would guess... replace it or repair it.
Do that before you spend alot of time replacing the fuel pump.Checkout my MR: http://www.cb7tuner.com/vbb/showthread.php?t=165984
