H22 auto tensioner conversion FAIL
    About 30 minutes ago I was converting the auto tensioner on my new JDM H22 to manual when I broke off a peice of the oil pump housing while tightening the adjuster base bolt. I had threaded the bolt by hand until it was too snug, then I started to tighten it with my torque wrench when the threads broke off the housing.
    I suspect that I will be forced to purchase a new housing, but can someone please confirm my suspicion before I make the purchase? I know using JB Weld would probably be a little sketchy, but is it out of the question?
    Thanks
    something that requires 20ft-lbs i recommend not to tighten with a TW
    people think with torque wrenches nothing can go wrong
    bolts stretch, threads weaken, TW have to be calibrated also
    if you were scared of the bolt loosening itself, lock-tite would have been the answer
    Jb-weld works great, but i wouldnt suggest you use it on this part, being that it its key to hold the tensioner
    oilpumps aint that expensive, you can find one here for cheap
    if you're concerned about the donor pump, just swap your pump, and use the donor housing
    note: when removing the pump use an impact driver to remove and to tighten it, try not to break anything
    Just do what PR CB7 said.
      Ok, so a new HONDA oil pump assem is $197, not to mention the PITA it will be to install it. My new question is...should I just put a new auto tensioner on and forget the manual conversion? If I go this route, I won't have to replace the oil pump housing because the auto tensioner doesnt use the adjuster base bolt, which will be a huge load off my shoulders. Will a stock H22 really put that much strain on the auto tensioner?
      Really looking for some input here...Deev?
        Bueller?
          just get an aftermarket pump or find a good used one. take it apart, inspect it, loctite the bolts and slap it on. Ive reused many pumps with no issues as long as it is inspected and cleaned throughly.
          the manual tensioner is worth the money and time.
