i recently put all new lower bearings in my motor. wen i tried to crank it the other day, my starter was just clicking. so, i got a new starter and the same thing is happening. i can barely turn the motor over by hand. whats going on?
engine wont turn over
first question, why did you do lower OR crank bearings ?
second question did you measure the crank and rods and journals to determine what size bearings you needed?
third question while assembling the engine did you turn it over to make sure that it spun freely?
if no to these questions, you may have to start over again
i spun a bearing so i needed new bearings. yes i measured and yes i turned it over while installing and it spun like it should. The battery is brand newOriginally posted by bobbycos View Postfirst question, why did you do lower OR crank bearings ?
try the old check all the grounds trick, its a possibilityOriginally posted by 1993 CB7 LX View Postcould it be the main relay?????
Unplug the small spade wire off the starter (ignition wire) and jump that terminal on the starter straight to POS on your battery. That will bypass everything between the ignition and the starter. Car should turn over and possibly start when you do this. Someone will need to be holding the clutch in and the ignition will need to be in the RUN position (II) in order for the engine to fire and run. And to be clear, when the car starts (assuming it does), remove the jumper wire from batt POS lol
