Ground bolt on valve cover
    Anybody know what size the bolt is that attached the ground to the valve cover? Just noticed I lost mine in the process of doing my Valve cover gasket.....
    93 LX - Needs work
    It should be a 10mm but not sure on the thread pitch.
    Yes my name is Dang, Don't use in vain
    1992 Honda Accord EX (Coupe/Bordeaux/Auto)
    1992 Honda Accord EX (Coupe/Bordeaux/H22A MT)
    2008 Honda Accord EXL (Coupe/SanMarino/6spd)
      Trial and error seems to be a reasonable solution to this dilemma. Considers tiny bolts aren't very expensive. Would it be a bad thing that I moved the ground to a bolt on the power steering module? Considering my power steering doesn't work I figured better than nothing for now.
      93 LX - Needs work
        Your best bet is to just go on www.hondaautomotiveparts.com and order a new one. Or better yet... hit up a junkyard. Bolts are pocket size.
          LMAO. Good call deev. Didn't even think of that. I need a piece of frame for my CB7 anyways. Good website btw. Haven't seen that one before.
          93 LX - Needs work
            The bolt should be M6x1 thread pitch like most 10mm headed bolts on Honda's. Junkyard is the best bet but you can also get a new bolt from certain auto stores and Home Depot. It'll be either labelled M6x1 or M6 fine thread.
              Very detailed response. Awesome! Also. Your post count is 666......
              93 LX - Needs work
                ^^^ Not that i like pointing out signatures but that one is hella annoying.
                  Yeah. I didn't think it would be that big. Tried to resize it. Decided to just change it. Having trouble finding something I like but I changed it to something that doesnt flash for now.
                  93 LX - Needs work
                    Much better
                    Thank you.
                      No problem. Didn't realize it was quite that seizure inducing before I uploaded it. heh
                      93 LX - Needs work
                        No problem. And I realized the 666 after posting as well lol.
                          Makes me wonder whether to listen to you or not. I helped get you past evil.
                          93 LX - Needs work
