I'm ready to start building my H22 and I wanna start with the head . My CB is my daily driver so I'm gonna have to buy another head to install the new parts on . A guy in my city has a F20B head he's selling for $100 bucks , I really wanna grab it . I'm gonna be doing a Skunk2 build and I know the H22/F20B parts are the same . My question is would the F20B head fit and run fine with the H22's block ?
F20B Head on H22 Block ?
I would almost rather build a F20B instead of the H22, mainly because the H22 sleeves are composed of FRP, whereas the F20B sleeves are made of iron. I've heard that the FRP sleeves don't hold up nearly as well and are actually one of the biggest reasons why H22's are notorious for burning oil. One thing you could do is just have the H22 block re-sleeved with iron sleeves instead of the FRP. Just a thought.
Do you mainly want the F20B head because it's so cheap, or do you have other reasons?
FRM, not FRP.
The oil burning issue with the H22 is actually pretty exaggerated. Much of that reputation comes from people that haven't maintained their engines. Hell, I've beaten on my H22 pretty hard, and it has never had an oil burning issue. FRM sleeves are light, strong, and excellent at dissipating heat.
I believe the F20B head is very similar, if not identical, to the H22A. I'm not 100% positive, but close. I know the cams are the same.
If I'm not mistaken, the manual version of the F20B has the same cams as the H22A type S. I don't know if the extra .2 liter is what makes the extra 20 PS though.Originally posted by deevergote View PostFRM, not FRP.
Yeah, you're right. Manual as Type S cams, auto has regular H22A cams.
The F20B has a 85mm bore, whereas the H22A has an 87mm bore, so that may be a concern. The combustion chamber diameter on the head will be smaller than that of the block. If you're going to have the head modified, that can be corrected, however.
the f20b head should fit on the h22 block....but remember the f20b head is meant for the 85mm bored sleves and the h22 bore is 87mm...u would probly have to have the head bore matched to the block...shit if worst comest to worst buy the head and match the passeges to the h22 head gasket.if it dont fit just sell it on here in the classifides im sure theres a few ppl that would buy it.
