new suspension
    new suspension
    okay i have never bought new struts or anything suspension wise for my car and i was wanting to know what kind i should get. i was thinking kyb struts and shocks. i dont really want to lower it if i do maybe an inch but nothing more because i dont want to mess with my wells or get a camber kit just yet.
    sorry for the stupid questions but im new to this and would like help.
    sincerely,
    Remington
    KYB AGXs or GR-2s will be fine. Tokico HP Blues and Illuminas are ok choices as well. Koni Str.ts would be the best mild choice in my opinion. Not really sure on your budget but do some pricing and see what fits you best. Add some coilover sleeves from perhaps Megan Racing or some simple sport springs like Eibach Sportlines, Neuspeed Sports, and H&R Sports for that simple 1in drop. Or if you've got some money to spend, I would say for the best ride and looks Function and Form Type 1s should do you no wrong.
    '94 JDM H22A: 178whp 146wtq
      alrighty!!! thank you!!!
        i think im gonna do the Tokico Blues with H&R lowering springs which should only lower it 3/4inch. because i dont want to cut into my wells for my control arms.
          Who said you had to? It's not necessary, unless you want to slam your car to the ground...and even then you still don't have to.
            You never HAVE to cut your fenderwell... in fact, I think it's a really stupid thing to do in the first place!
            Which H&R springs are you looking to get? A drop of less than 1.5" will be very difficult to notice.
            Also, keep in mind that the shocks you get will need to be able to handle the drop AND the spring rate.
            If you want a very mild drop, I suggest getting the Tokico kit that comes with springs that drop an inch or less, and the Tokico HP shocks. It's not a very performance-oriented setup, but it's fairly inexpensive, and properly matched.
            KYB shocks, even the adjustable AGX, are really not good for a lowered car (though your 1" or so plan would work well enough... they shouldn't go lower than 1.5")
            Personally, I think if you want a very mild drop... get some Koni STR.T shocks, and pair them with H&R Sport springs. That will give you a 1.5" to 1.8" drop, and as long as you get your toe aligned, camber wear should be minimal (it will still happen, but it won't be terrible.) A quality camber kit like SPC or Ingalls (I wouldn't trust cheap crap for safety reasons) can be used, and you can adjust the camber to be only -1 degree... which, with a mild drop, will result in no hitting of the fenderwell, and unnoticeable camber wear.
              oh okay!!! thank you guys! your a huge help!!! im gonna do my suspension right after my h22 swap!!! im so fricken excited! im pickin up the motor tomorrow!!!! so ill post pics of my car tomorrow and the engine. it will be a slow swap but i would really like you guys to criticize me and give me pointers and cool ideas to do to my car. ive been thinking alot and have alot of ideas but i like others thoughts.
                koni yellows and h&r springs....are a good set!!!! popular toward tuner!! world
                VS
                Mercyboy: I rather lose by a mile because I built my own car then win by an inch because someone else built it for me..your car is your story, so don't let someone else write the book!
                MERCYBOY THREAD:http://www.cb7tuner.com/vbb/showthread.php?t=158241
                1990 RHD Honda accord si CB3 Canada http://www.cb7tuner.com/vbb/showthread.php?t=196287
                MY CB7 ON YOUTUBE: http://www.youtube.com/watch?v=CJID_IxwiNY
                  X2
                  If you have the cash I will also recommend the koni yellows. You can pair them with the nuespeed sport pr H&R spring.
                  I only say this to you because you mentioned that you only want to drop an inch "right now". Going with this shock will allow you to run a mild drop spring like those two I mentioned, and if you want to go further and get a set of race springs you can keep the same struts.
                  Another thing to consider is that rear camber can be adjusted using washers. This means that camber wear will only happen on your front two tires, you can rotate and get better life out of the set of 4.
                  Also as mentioned camber wear is very minimal on that small of a drop.
                  Good luck with the H swap. If you got a good motor and follow the guide, you should have no problem.
                  201 Whp H22a with bolt ons, see the progress from stock f22a to now HERE
                    thanks for the help guys!!
                      The best setup i came across when i had my cb was Progress springs + KYB gr2s + proper alignment.
                      Car handled flawlessly. Great for a daily driver.
                      This time around i think i would try the kyb str.ts as i hear they're a great compromise for daily driven, lowered cars.
                        yeah thanks this is one of those "direct suggestions" that newbies like me can take as a for sure starting point.
                        Koni Yellows and H&R springs it is.
                          KYB doesn't make a single thing that is designed to handle a drop greater than 1.5", or a spring rate significantly stiffer than stock. KYB shocks are a lousy performance option for us.
                          Also, the STR.T is made by Koni, not KYB. They are decent, will handle most drops, but the Koni Sport (yellow) should be used for anything extreme.
