will the distributor from a f22a6 fit on a f22a1??
Distributor
You'll want to check the spark timing after you change the distributor, because it'll probably change. You can try marking your existing disrtibutor where you adjust it and try putting a mark in the same place on the new one, but more than likely your timing will be a bit off after swapping.
Just line up the rotor with #1 cylinder terminal before you remove the old one and make sure the new one is in the same position when you install and you will at least be close.
