high idle please help!
    hi,
    2 weeks ago i swapped a h22a in my 92 accord, running on a chipped p28, i drove it around for a week or so, all was perfect
    but last week after an highway ride, i realized my idle was at 2000rpm and stayed there. since then, it does that engine hot or cold doesnt matter..
    i tried just about everything, checked for vacuum leaks, replaced the IAC by the one that was on my f22, i checked if the FITV screw was loose (it wasnt yet i screwed it in a bit more), i sprayed carb cleaner a bit everywhere to find vaccum leaks, i flushed and refilled my coolant fluid, i played with the idle screw, long story short ive been on this problem for 1 week, tryed everything and nothing fixes my problem
    after doing all that and 1 week later problem is still there but after i drive it around a bit, my idle will go up and down a couple times before camping at 2000rpm again...but i checked the FITV so i dont think its related
    now my last option is a bad TPS...is it possible a bad tps can cause ur idle to stay at 2k rpm??
    i did lots of research, i did use the search button (on more then one forum trust me) and i found countless post with similar problems but none with a final solution and no one around me seems to be able to help me...tbh im desperate and about to give up, this is above my knowledge, please if u know the solution...help me!!!
    MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201008
    Does your throttle cable have the correct amount of tension?
    Deev and I are buds
      sticky throttle cable?
      92ex CB7<-SOLD 93ex CB9shiftingshift73C10
        There is a thread by HondaFan81 that tells you how to set your base idle properly. Search for it, and do what it says.
          Originally posted by Cb7_Qc View Post
          hi,
          Try this http://www.cb7tuner.com/vbb/showpost...33&postcount=1
          if you've done all that already, then there might be oil leaking into your spark plugs or change most of your fuses that helped mine
            Another member had the same issue, upon inspection of the TB he discovered there was carbon build up on the valve and was keeping it open just a bit. And its possible the tps could be dirty, or damaged in the swap. There is a thread on here about how to test it and adjust it. And my gf's cd5 should do the same thing, but it was because there is a stop on the throttle cable that got caught in the piece of plastic that the cable ran thru, dunno if that same thing can happen on your swap, might be a cd5 specific cable deal.
              according to hondafan81's thread, if i cannot adjust idle then i have a vaccum leak..ok...but i checked for everypossible vaccum leak i could think of
              i plugged/unplugged every single hose, i pinched everysingle hose with pliers, i even sprayed carb cleaner everywhere to see if idle would react somehow, in fact, a vaccum leak is the first thing that came to my mind but i couldnt find any
                I would check all the bolts that hold the IM to the head, my old idle issues arose because one of the lower bolts behind the thermo housing came loose....stupid gremlins
                  the problem was my intake manifold gasket, it was missing a 1'' chunk on it!!
                  we did not find it at first with the carb cleaner because the missing piece was on the bottom of the gasket, had to soak the intake manifold in carb cleaner until the stuff would leak down to the vaccum leak....
                  anyways, problem solved, car is running great and i just got my ass whooped on the track by a b20 lsd civic lol
