h22a4
    h22a4
    Can I use a 99 obd2 intake manifold in my 92 ex? maybe use my TB?
    K20z3
    Yes. Only difference from obd2 h22 is the dizzy plug, injectors, and ecu...u have to use your stock map sensor...u don't need the one that's on the tb
      Are you putting the manifold on another H22, or an F22? Only the top part of the intake manifold will work on your F22. An H22 throttle body must be used as well.
        i got a whole h22a4 swap for my 92 ex...
        so just a dizzy and injectors?
        K20z3
          also its an auto car and im keeping it auto. I was thinking about a chipped p28. do i need to use a auto p28 or with a manual one work?
          K20z3
            You can use the p13 auto or Manuel it dosent matter, same with the p28. Just use your stock f22a TCU, if your keeping the f trans.
            And yes you only need obd1 ecu, injectors, and dizzy for your h22a4 to work on your cb, you can use the dizzy from an h23 or f20a dohc...
